跳转到主内容
This LG Android device was released in October of 2015. The model number of the device used to create these guides is LG-VS990.
20 个问题 查看全部
Why is the right side of my phone screen flickering?
I bought my device on Amazon in September of 2016. I had no problems the first couple weeks I got it. Then one day half the screen started flickering specifically the right half. There are coloured lines and it is shifted. It is still responsive and strangely when I rub on the flickering half it will take its time and clear up but will return to flickering and jumping once I stop rubbing it.. When I take screen shots the flickering doesn't show either. The picture comes out clear. This is a picture I found on line of a G4. My screen sometimes looks like that, other times its clearer and resembles the normal half of the screen and whatever is on it. I did not drop my phone in water or drop it before any of this started. I have tried factory resets and disabling hardware overlays and none of that worked. http://m.imgur.com/v2aWo6C?
I'd appreciate any help other than sending it back to the person I purchased it from.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
seem to see alot of people having this issue , you would think someone from lg would be on it , these phones get to be expensive , not very durable
完成的
添加一条评论
6个答案
最有帮助的答案
The same problem started today on my LG V10 H961N. Need some help please.
这个答案有帮助吗?
得分 1
2条评论:
That's sad. I'm still with this problem on my LG V10. Another problem is that I bought this phone in another country, so, in my country I don't have anywhere to fix it, because this phone isn't produced here.
完成的
So did any of you find a solution? Mine started flickering now, after a year - exactly when the guarantee stopped... is it the software or is it a hardware problem? I'm really clueless and very desperate...
完成的
添加一条评论
Today i'm with the same problem in my LG V10. Did you fix it?
这个答案有帮助吗?
得分 0
1条评论:
Nope, sorry.
完成的
添加一条评论
and this happened to my LG V10 H691N
did you have solution ??
这个答案有帮助吗?
得分 0
1条评论:
No luck, sorry.
完成的
添加一条评论
I've had this happen on two of these phones. No more LG Phones for me.
这个答案有帮助吗?
得分 0
添加一条评论
I tried everything and the only thing that worked is installing an app called "screen filter" available for free on the play store. It resolves the flickering issue by adjusting the brightness level.
Let me know if it worked for you guys too.
这个答案有帮助吗?
得分 0
添加一条评论
https://youtu.be/zUG4iVJxCBQ
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alexandria Green 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 4,839
