跳转到主内容
iPad Mini 4 发布于2015年9月9日,有着类似 iPad Air 2 的性能和更小巧的身材。
176 个问题 查看全部
Possible to Have Sleep / Wake without Magnetic Sensors Installed?
Hello everyone:
I've replaced a damaged LCD/digitizer. I didn't know when purchasing the part that some components needed to be transferred over from the original display. I believe I have everything transferred except the small cable with components that needs to be soldered onto another cable just left of the home button (when looking from behind the display). I don't have the equipment to solder that on, and decided it isn't worth the expense of paying someone else to do it. I did put tape over the pads so they don't get shorted - but I did close up the case at least once before putting the tape on (though I've erased all content and settings since).
Apparently because of this, manual sleep/wake does not work. Automatic (time-based) does. The power button does work, because I'm able to turn the device on and off with it.
I don't understand why the cable would need to be connected to have manual sleep/wake (using the power button) functionality - my understanding is that it is only used with special cases to activate the feature when the tablet is stored.
There is apparently a "cover lock" setting that would be nice to experiment with, but it doesn't show up in my settings - even after erasing all content and settings.
I've even tried using the "assistive touch" feature, but using the lock option there doesn't work either.
I can live without manual sleep/wake, but if there's something that can be done (once!) before sealing this thing up to get the feature working I'm willing to give it a shot. Something like, for example, putting a short or a load across some pins to simulate a magnet sense, which may result in the "cover lock" setting showing up, which I could then turn off (or on?). Or a service menu or app where I can see/modify information on the sensors?
Any ideas would be much appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
There are a couple ways to trick it if you’re using an aftermarket screen that does not have a sleep/wake sensor installed. First, update the pad to the newest OS since this work around goes away once you update or restore the device. We figured out some work-arounds a couple years back when we got a huge shipment of mini 4 screens that did not have sleep/wake sensors installed.
  1. connect the original screen to it that has the sleep/wake sensor attached. Turn the device on. Using a smart case (or a magnet in just the right spot), get the device to sleep/wake when closing/opening the device. You will hear a “click” as the screen goes black. In settings, go to Display & brightness and turn off the Lock/unlock switch. The sleep/wake button will now work correctly when you install the new screen that does not have the sensor installed.
  2. ——OR——
  3. with the aftermarket screen installed and the device powered on, use a small piece of conductive metal to jump the connectors where the sleep/wake sensor WOULD be installed if it were present. When you make the connection properly, you will hear an audible “click” and the screen will go black. When you go to Dislpay & brightness in settings, the Lock/unlock switch will now have appeared, turn it off, and the sleep/wake button will work normally.
这个答案有帮助吗?
得分 1
1条评论:
Wow, thanks Chris! It’s so nice of you to help, especially considering how old my post is! I do still have this iPad, but no longer the original display. I’ll be trying option 2. This is exactly the kind of info I was looking for. Thank you!
完成的
添加一条评论
Just hit the power button.
这个答案有帮助吗?
得分 0
4条评论:
Hitting the power button doesn't currently activate sleep/wake, which is what I would like to be able to do. Maybe I wasn't clear enough.
完成的
It should. So fix the power button first.
完成的
The power button isn't broken. It still turns the device on and off.
完成的
OK, it appears that the missing hall effect sensor will cause the sleep/wake function to latch up completely. From what I know it is not possible to manually assert the signal since it is a digital interface. You WILL have to put the sensor back to restore this.
完成的
添加一条评论
添加你的答案
kmcrawford111 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 27
总计 2,274
