跳转到主内容
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 个问题 查看全部
Water Damaged Mac, Can I Fix It? [W/ hardware diagnostic photos]
#1
Hi guys,
My water bottle broke in my bag and caused water damage to my mid-2014 Macbook Pro with Retina Display
After drying out it seems to be pretty much fully functioning. However, it does not power on unless it's connected to power. I ran a hardware diagnostic and it seems like my battery and battery sensor are out
(photos here and
here). My question is if I just get a replacement battery will it fix the sensor as well?
[I understand I should just get a new laptop, like they told me at the Genius Bar, but being a struggling Uni student I'd like to leave that as the last resort]
Any helpful advice would be greatly appreciated!
Cheers,
Serena
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Best solution is to buy and try a test battery. If it is showing the percentage top right, it will most likely be the battery. If it is showing an X, it could still be the battery, but it could be the logic board, where the battery power is not making it through properly.
Be aware the batteries are glued in on the Retina's, so I would recommend looking at some videos first, to see if you will be able to replace this. If not, go with a 3rd party company (with good reviews of course), since most will just replace the battery instead of the whole palmrest, which is more expensive.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
SerenaSydney 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 759
