跳转到主内容
宏碁上网本系列的维修和支持指南,包括Aspire One系列。
20 个问题 查看全部
Wireless laptop adapter not working but usb ONE works!
Hi
Laptop- Acer Aspire 5745g, Inbuilt wifi adapter -Broadcom 802.11n
OS- Windows 7 professional, all drivers updated as per acer driver guide.
My laptop inbuilt wireless adapter suddenly stopped working (I do not remember, what changes I was doing). So after uninstall/reinstall of wifi drivers , I am currently using external usb adapter (Dlink Micro), which works good.
I use to connect to mobile hotspot and Home-Wifi, both works under external adapter.
But something is strange. Now I have two wireless configurations
Wifi@laptop - for Broadcom
Wifi@Dlink - for external adapter.
When I am connecting (from Wifi@Dlink) to any of two networks the strength is full, at same time in Wifi@laptop shows nil or one bar. If I try to connect to wifi@laptop network, it gives message as "Unable to connect to ... network"
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
It seems as though you may have a faulty Broadcom WLAN module or that one of the antennas has come loose.
Here is a link to the service manual for an Acer Aspire 5745 series laptop. While I realize that it is not your particular model it should be close enough to be relevant. It is different from your model in that it lists Atheros and Huawei as being the type of WLAN module available rather than Broadcom (see p.171 for listing and part number).
It shows how to access the WLAN module to remove it. Scroll to p.60 to view the pre-requisites and then the procedure to remove the WLAN module.
If you find that the antennas are connected properly it may be that the part number for the WLAN module in your laptop is "stickered' on the module. If you search online using just the part number only you may find suppliers of the part. If the price is right you may wish to consider whether replacing it is an option. Alterantively it may be that the Atheros and Huawei modules most probably would also work.
https://www.manualslib.com/manual/1197/A...
Hopefully this is of some help.
这个答案有帮助吗?
得分 2
3条评论:
@jayeff thanks. I will check and reply
But in this line I like add some more points.
Once or twice I switched to wifi@laptop and it got connected. I was able to download some files also. The signal strength was partial as compared to wifi@dlink. Then next day it was gone...
So it may be the loose connection problem.
Let me check.
完成的
@jayeff
hi
exact solution. I opened the back panel and found that the connector of wlan module was disconnected. Now fixed and its working fine.
Saved from buying the external adapter (which I had borrowed).
Thanks you are lifesaver!!
完成的
Hi @cpicsonly ,
Glad you got it going. Enjoy!
完成的
添加一条评论
添加你的答案
cpics 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,351
