跳转到主内容
The Samsung Galaxy J2 is an Android smartphone that was released in November of 2016.
100 个问题 查看全部
Why is my system memory use 7 gb out if 8 gb?
my phone is samsung galay j2 model number is SM-J200G
THE PROBLEM IS THAT MY PHONE IS USED 7 GB FROM OUT OF 8 GB I CANT USE MY PHONE PROPERLY.
WHEN I READ THE SPECIFICATION OF THE PHONE IT USES AROUND 3.4 GB
SO WHAT IS THE PROBLEM?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
4个答案
已选择的解决方案
Because of formatting, and what is used for the OS. The amount of physical memory installed is 8 GB, but you lose a few hundred megabytes due to formating, and a gigabyte or two for the OS. This is true of all storage devices. Totally normal. The rest of the free storage is used for apps, games, music etc. Luckily, that phone has an sd card slot so you can add more memory with this.
Hope this helps!
这个答案有帮助吗?
得分 5
添加一条评论
最有帮助的答案
Do you have a lot of apps ? Or pictures or music on the phone. They all take up space . Get yourself a micro sd card and move your stuff there and free up the internal memory. Hope this helps
这个答案有帮助吗?
得分 7
1条评论:
My friend thanks for your answer but It's not what I ask. In the storage area when you enter in seeing the phone storage space there are a lot of lists and one of them is system memory. It means that run the whole device. It takes 7gb out of 8gb how is it possible?
This is my question.
P.s I didn't install any softwares on it except it's factory version and also I have sd card the photos and videos are in it.
完成的
添加一条评论
I have a 8gb galaxy on5 and there is 4. Something gb used in my system memory in my internal storage, there is gotta be a way to delete whats in that system memory, no matter how many times i reset my phone
这个答案有帮助吗?
得分 4
1条评论:
No onextra is telling a bottle system memory and that is.main problem occupied lot of storage space.
完成的
添加一条评论
I have also this problem.But i can fix it.
Factory Reset your mobile and try it.
I 'm ok now.
Thank
这个答案有帮助吗?
得分 2
1条评论:
I have samsung j2...after software updating my phone storage is full even my phone is empty.update software consumed all storage(99%) what should I do now
完成的
添加一条评论
添加你的答案
FAYZ JEMAL 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 32
总计 31,444
