My Glass is crack on my BLU phone
I have BLU Studio 5.0 pink and the glass is cracked can i just replace the glass or do i need buy the lcd with the glass......
Check to see if the LCD is cracked. You can tell if it has cracked better in the corners. It will also be easier to tell if you remove the digitizer/glass. If it is cracked, you will need to replace it. If just glass is broken a replacement will be $10-15. But if the LCD is cracked a replacement for that will be $20+. Hope this helps.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 147
