跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Did I kill my phone/battery?
Hello !
So I have an iPhone 6 Plus that I had to replace screen on (months ago) and it was working fine until about two days ago. It started doing this no signal/ no service mess but if I bent the top of the phone by signal came back. I opened my phone (which I've done confidently on many of my iPhones) I was looking for the antenna and disconnected the power cable to my sleep/wake button. I plugged it back in when I realized I never turned my phone off but it wouldn't work, so I unplugged the battery.
I plugged everything back on and now my phone won't turn back on. I tried plugging it up to the charger, a hard reset. Nothing. And there is a weird warm spot or the top of my phone near the camera
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Can you confirm if you removed the screen assembly or not, it's not clear in your question?
If you did remove it without disconnecting the battery first, you may have damaged the backlight circuit.
Follow the recommendations by @rayeasom but in addition I would also do the following:
  • visually inspect the connectors with a magnifying glass or jeweler's loupe to see if there is any damage to the connectors or surrounding components.
  • verify that you have put the right screws in the right places. iPhone logic boards can be damaged by putting longer screws in the wrong place. Follow this guide.
  • with the phone "turned on", put a bright flashlight on the screen and see if if faint image is visible. If you can see an image, that would be indicative of a defective backlight circuit.
Regarding your original "no signal" problem, I would be concerned about the fact that torquing the frame made it work temporarily. The iPhone 6 Plus is well known for have a bendy frame and it sounds like your device has had its share of flexing. You may have some latent logic board problems that will continue to surface.
这个答案有帮助吗?
得分 1
3条评论:
Thanks you both. I plugged it up to my computer again and it recognized there was a phone on iTunes but it's locked so I'm guessing I just messed up my screen.
As far as my signal issue, any tips on how to combat it ?
完成的
You could have antenna problems or with the baseband IC' (see my flexing comment above).
完成的
I doubt baseband IC. More like backlight circuit having issues if the phone detects as being locked with passcode on iTunes. It means at least the phone can turn on and boot successfully.
完成的
添加一条评论
id start by checking all the cables are connected properly and free from any dirt/obstructions. Connect your phone to a computer that has already been "trusted", does iTunes recognise your phone if not try a new battery, if it does the fault lies either with the display or the display IC.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Crystal 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 107
