跳转到主内容
Also called the Crosley Musician Entertainment Center.
Why does the record player play slowly
the record part of this machine plays the records slightly slower than they should be played. I am curious if there is a repair option for this, and where to look? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I just saw this post! This was my issue as well. Thank you!!!!
完成的
添加一条评论
3个答案
最有帮助的答案
I had this same problem. Turns out that I didn’t have the lid open fully abd the vinyl was rubbing slightly on the lid!
这个答案有帮助吗?
得分 2
1条评论:
You are amazing thank you so much I was literally freaking out over this. Super helpful my guy thanks again
完成的
添加一条评论
I'm not sure how old yours is, but I'm guessing since it has a disc player it's pretty new. I have a different brand player, produced in the last ten years, that slows down often. To adjust the timing on it there is tiny mechanical part on the inside that you can insert a jewelers flat head into and lightly turn to adjust the timing. I usually pull up a song on YouTube and use it to compare to the record. However if you adjust it while a records on you risk scratching.
Mine slowed down so often I drilled holes in the bottom to access it without tearing the player apart everytime just to adjust it. After all I can't listen to The Bee Gees slowed down
-Liz
Here's an image of the part, I have three, one for each speed.
这个答案有帮助吗?
得分 1
1条评论:
no only a motor underneath. no place for adjustment. sad
完成的
添加一条评论
Your belt underneath the platter is either stretched or slipping.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dan Strickland 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 53
总计 12,130
