跳转到主内容
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
62 个问题 查看全部
iPad Mini 2 will only charge if turned off first
After replacing the battery of an iPad Mini 2, I've found that it won't charge unless turned off first and then plugged in.
The steps that I've tried so far are:
  • Tried another battery
  • Factory reset
  • Tried various chargers and cables, both original and knock-offs
Any ideas? I've tried Googling and can't find anyone with a similar issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Have you calibrated the new battery? Sometimes, uncalibrated batteries can cause issues with smart devices. Drain battery below 10%, then charge uninterrupted to 100%.
You may also want to check the specs on the replacement battery if you didn't get it from iFixit, as well as ensure that the proper safety certifications are in place to prevent the iPad from becoming a $500 charred smelling paperweight. Check mAH (milliamp hours) and voltage. If you're having trouble with a non-iFixit battery, try the iPad mini Battery from iFixit (and no, I'm not getting paid by iFixit to say that).
I've also encountered scenarios where the device needed a particular sequence after installing or reinstalling a battery:
  1. Turn off the device and unplug the battery
  2. Perform a hard reset without the battery
  3. Plug the battery back in, and perform another hard reset with the battery.
iPad mini Battery图片
产品
iPad mini Battery
$29.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dillon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 2,044
