跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
iPhone 5s stays at 1 percent battery and never charges up.
I have an iPhone 5s and I changed the entire dock connector part, because the jack connector was giving crackling noise when I would plug my headphones.
After that, the phone stopped charging.
So what I did is:
-Put a new battery in
-Put back the old dock connector part
-clean all connector and the motherboard with isopropanol 99%
Nothing solved the problem. The percentage is still stuck at 1% and the phone goes off 30 seconds after I unplug it, and when I plug it to my computer again, the screen stays stuck at the red battery screen, even after a few hours. However, the phone DOES get recognised by the computer. The only thing not working is the charging up.
The only way I can use my phone again is to put it in DFU mode and Restore.
What could be wrong in my case?
PS: Some screws are missing on my dock connector part, can that prevent things from working?
EDIT: this is what happens when I unplug the battery and connect the iPhone to my Mac:
https://www.dropbox.com/s/oti1otfx1q0cfv...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Using the guides to give you specific details on how to do this:
  1. Unplug the battery
  2. Perform a hard reset on the device without the battery
  3. Plug the battery back in
  4. Perform a hard reset again, this time with the device on
  5. Calibrate the battery, instructions can be found in the battery replacement guide.
这个答案有帮助吗?
得分 2
4条评论:
Probably a bad U2 Tristar charging ic if restore does not work.
Also about screws missing on charging dock it should not effect charging as I test charging flex ribbon cables without fully installing them to see if it is charging the battery.
完成的
Thanks for your response. Somehow I managed to get it to work after having unmounted and remounted the entire piece.
The battery charges up to 100% as normal, and charges back up again when I replug it after use. However, once it reaches 0% and turns off, it's stuck on the red battery icon and doesn't charge up. I tried to restore again. The restore starts working but it gets back to that red battery icon again...
So the iphone charges up when it's on but doesn't when the battery is at 0%. Does that look like the IC chip being faulty?
Thank you
完成的
This is what happens when I unplug the battery and connect the phone to my Mac:
完成的
Yep. I'd get the U2 Tristar charging IC replaced because it is a symptom listed on here:
https://www.mendmyi.com/blog/2014/06/has...
完成的
添加一条评论
添加你的答案
Alex222 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 19,435
