跳转到主内容
The Brother MFC-240C is an all-in-one color inkjet printer.
29 个问题 查看全部
MFC-240C does not print - despite fresh cartridges and multiple purge
My Brother MFC-240C prints in black, but in none of the colors. I have already installed new original Brother ink cartridges, and executed multiple Normal/Power Purge runs (using the Maintenance Mode as described in the service manual, chapter 9 / 9-43). The problem persists.
Can anybody help? Has anybody successfully disassembled the printer, and cleaned manually the ink supply tubes and/or the printing head?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Print head could be clogged and needs some cleaning. Check Youtube for videos on cleaning...Ink have expiration too, it could be old and dry.
这个答案有帮助吗?
得分 2
2条评论:
Thank you for your suggestion. It is absolutely correct. I have disassembled the entire printer with the help of a detailed service manual for MFC-240C. This is necessary as the print heads of Brother inkjet printers are located deeply inside the printer. Cleaning the printhead with distilled waters, followed by some purge operations (in the printer's service mode) helped.
All colours appear again perfectly. My old printer got a second life :)
完成的
You are welcome. Where can I see the service manual for MFC 240-C, I hope you don't mind?
完成的
添加一条评论
添加你的答案
Markus 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 22
总计 2,050
