跳转到主内容
苹果Magic Mouse鼠标是由苹果公司制造和销售的多点触控鼠标。它于2009年10月20日首次公布和销售。
Why won't it turn on?
Inserted new batteries. Batteries are in properly. Battery & mouse contacts are clean. Green power light does not come on. Mouse does not function.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You may have some corrosion internally within the mouses logic board. Have you tried opening it to see if you need to do some deeper cleaning? Also you could have a bad solder joint in the power section . Trace the power feeds from the battery compartment with an Ohm meter and don't forget the switch.
Sadly, Apple does not offer parts for the mouse so if you have a bad switch you'll need to get a new mouse.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Joe Milun 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 230
