跳转到主内容
Hands-free voice-activated device by Amazon powered by Alexa Voice Service. Model S04WQR.
Alexa can't set alarm for me. Says is a problem when I ask.
In past could set alarm by asking Alexa to set alarm for a time specific. Now she says alarm set...then few seconds later say problem setting same. Help, thanks and Happy New Year.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
I have 8 echo dots covering 3 generations...suddenly today only the first gen dot is able to understand what a timer is. The others reply with..."Hmmm, I'm not sure". Oddly, when I ask them how to set a timer they respond with, "say something like, Set a timer for 5 minutes", but when I do, I still get, "Hmmm, I didn't understand" or" I don't know that one".
完成的
添加一条评论
5个答案
最有帮助的答案
I had the same issue. My Echo Dot was connected to wifi and would interact and tell me the temperature.
Every time I tried to set an alarm it would take the command, and then about 5 seconds later respond and say it had a problem setting the alarm.
After reading this post I decided to try power cycling it. That seems to have worked - it took the command. It also is showing up in my iPad Alexa app.
Problem solved.
这个答案有帮助吗?
得分 3
添加一条评论
There is a problem connecting to the amazon alexa service. You should check if it is connected to wifi, and if so, if the wifi is connected to the internet.
这个答案有帮助吗?
得分 1
添加一条评论
Sometimes Alexa enabled device like mobile app does not support alarms or timers.
这个答案有帮助吗?
得分 0
添加一条评论
Open the Alexa app. On the side menu, go to reminders and alarms, click the alarm tab and push the button to the on position
这个答案有帮助吗?
得分 0
添加一条评论
Just go to settings and choose factory reset option.
Follow the instructions and your problem will be solved…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Larry Hirsch 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 24
总计 24,687
