跳转到主内容
The Nokia E7-00 phone is a business-oriented smartphone with a built-in keyboard. It was released in 2011.
1 个问题 查看全部
How to change the USB port?
The USB port of my Nokia E7-00 has some bad contacts, depending on the angle of the USB wire with the phone, the phone is not charging or unable to transfer data to a plugged computer. I would like to change it but I don't know how and I'm a little bit affraid of trying without any advices.
I'll be very glad if someone could help me about this.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
i finally had a go at analyzing this common failure ...
the root cause is that the plastic part within the usb port has/develops a tiny amount of wiggle room. this wiggle ultimately causes the outer pins to snap off right in the "knee" of the "L" shape which attaches to the PCB.
you can replace the socket (it costs "nothing"), or you can solder tiny bent wires to it - i did the latter, and it actually worked (dunno for how long).
you will need a hot air gun, a preheating plate (the motherboard sinks so much heat that there is no way hot air alone will be enough), flux, and a little fresh solder. if you do the wire magic, you'll also need equipment for soldering tiny parts - a short-shafted pointy soldering tip (J shape), a magnifier, and a sufficiently steady hand.
you can try closing the gaps in the broken leads while the socket is still soldered, but i don't think it will work, as the solder is unlikely to flow that deep, esp. with the enormous heat-sinking of the PCB.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sylvain 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 499
