black screen after replacement
i've just replaced my screen myself. after i connected the wires i checked the screen and it worked as it should. i then proceeded to put the screen in place but when i had done that my screen didnt work anymore. it just shoved a light dark color, like it was on but couldnt show anything.
i tried to switch back to old screen again to see if it was my new screen that was the problem. but the old screen did the same. i've seen now that the is a proection film on the inside of the screen i hadn't noticed before. could that be the cause of the problem?
Update (12/29/2016)
here sry for the late reply
Update (12/29/2016)
here are the pictures
7条评论
you might want to take it back to store where you changed you screen
由 daniel 完成的
Thanks for trying Magnus...unfortunately the focus is off. These are difficult pictures to take with just a phone.
由 Minho 完成的
And the new battery is in there?
由 iMedic 完成的
i havent replaced the battery. should i do that to repair it?
由 Magnus Mikkelsen 完成的
Can you take a another picture, but this time zoomed in on the upper connectors area?
由 Minho 完成的
显示更多的2条评论
