跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
New display show bright spot shortly after
Hello,
I shifted display and after a while it inhibits one brighter spot at the top of the screen, so I tried another display and sure after about a minute this display in the same area show a bright spot. I suspect the logicboard, anyone knows what can cause this?
Kindly
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Normally where there is a bright spot (or dull color) there is pressure on the LCD in that location.
Double check cable connections and that screws are secure. Also if there is any resistance at all when putting it back together, something is out of position. The screen should slide and click easily in place.
这个答案有帮助吗?
得分 4
1条评论:
You're right it's pressure. The original battery is a bit tucked at the edge, thus pushing the display in that area. Thanks for your insight!
完成的
添加一条评论
添加你的答案
Emil Eriksson 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 5
过去 30 天: 5
总计 438
