跳转到主内容
OS X does not inicialize
When I turn on my Mac, it just processes and finally It shut down instantly without entering the system what it may be? I tried to enter into security mode, but the same happens, I entered the recovery partition and tried to repair the disk, the Repair process fails and asks to backup the information, but without entering the system I can not back up the information, what I do now, how do I save all my information and recover the system? I have no time machine backup,
Update (12/27/2016)
Has no external ssd drive nor onther macbook with same ssd compatible, is ther onther option to same my information ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Do you have access to a second Mac? If you do you could try using Target Mode. The other option here is to take the SSD drive out and using a special case mount it into it which will allow you to access the files to a second Mac system.
If target Mode won't work you'll need to use the case method. It does sound like your system has a deeper issue here which is why it's shutting down. Once you get your files off the drive you'll likely need to look deeper on whats happening here.
这个答案有帮助吗?
得分 0
添加一条评论
target disk mode or external SSD adapter would solve ur issue
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aristides Guirrengane 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 73
