跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
pins of screnn on iPhone 6 motherboard broken
hello!
so non-professioanl Repairer took my iphone to fix the speaker he broke the motherbaord so now the iphone turns on i can hear the sound on my computer but nothing show on screen which means the motherboard doesn't recognize the screen from the pins on the motherboard i guess so !
like in the picture
if anyone can help me please!
thank you for advance !
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
i too have the same problm but it was broken at just apart side of the wifi flex cable-mobile is working but wifi,bluetooth and power button is not working-how it can be fixed-the broken motherboard was working because of the soldering at the broken area but i dont know how to fix blueoth and wifi problem id there any solution
完成的
添加一条评论
1个答案
已选择的解决方案
Wow, that logic board is seriously damaged. The FPC connectors for the LCD and front camera are damaged and most certainly not making proper contact. I don't understand how a non-professional repairer, working on a broken speaker, could cause so much damage on the top of the logic board? Was this from a previous repair?
The bottom standoff is also removed and we can visibly see the copper traces. The picture isn't really clear enough to see if this is a previous Long Screw Damage repair or something that just happened. The CPU shield is hacked away. Normally, if someone were to perform a LSD repair, they would remove the shield to have more space to work with.
So you need to have both those FPC's replaced and the bottom left standoff inspected. Hopefully there aren't any metal shards from the shield moving around underneath the shield.
这个答案有帮助吗?
得分 3
4条评论:
thank you very much for the help i really appreciate that !
so i will try changing the FPC's first and see if works
thank you very much for the help !
完成的
I would've just gotten the repair to either fix it or get me another identical phone in perfectly working condition or better.
完成的
Yeah, but considering how badly the guy f'd up the phone in the first place, I would just make him buy me a new phone
完成的
Jesus F**king christ how do you screw up a perfect mobo THAT bad.
完成的
添加一条评论
添加你的答案
Abdelkader Laib 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 1,901
