跳转到主内容
加入维修社区 - 创建账户
Screen shows gray lines
Hi, I've got two gray horizontal dot lines up screen (in the status bar area) and some weeks later a new one, this time vertical in the middle of the screen.
When connecting to a big screen, such as a LG LED TV on the thunderbolt port > HDMI, the lines doesn't appear.
Is this a LCD screen problem? Or could be on the graphics card?
Can someone give me some information about it?
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
This is a LCD screen problem. It sounds like dead pixels. Look on Wikihow on how to fix dead pixels. Best of luck!
这个答案有帮助吗?
得分 1
添加一条评论
If it was the graphics card that was the problem, then when you're mirroring to other displays it would show up there as well. However overall, the problem sounds suspiciously like the LCD is damaged. If you have Apple Care, Apple may cover it. Otherwise you're best bet, price wise (Apple 'aint cheap to fix stuff), is to go to a computer repair shop or consider a new computer. Because usually these problems get worse over time.
I had a similar problem with my Macbook Air (same model) but my case was far more pronounced and the screen changed colour severely with the computer needing a new screen. Again, Apple will charge a lot. But Apple Care will take care of the problem if you have it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cesar Barbosa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 773
