跳转到主内容
第三代 Surface Pro 平板,发布于2014年6月20日。
Does the surface pro 3 kick stand come with a hinge
The 2 little metal hinge connecting the kick stands are broken, Does the kick stand come with the hinges or can you post it with the hinge if possible.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Honestly, I would just get a case that has a kickstand.
UAG has a case with a kickstand. I am sure there are others out there.
Just getting to the Surface's kickstand requires disassembling the entire device.
Even then, I don't know if the kickstand is repairable.
Microsoft Surface Pro 3 Teardown
这个答案有帮助吗?
得分 2
1条评论:
I use the UAG case with the Microsoft surface Pro 3 and it is pretty good.
Covers the corners and around the screen really well without blocking air vents or ports.
完成的
添加一条评论
添加你的答案
Zeeshan Abid 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 812
