跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
convert iPod to flash memory
I have an Ipod classic video that came with a 160 Gig internal hard drive. of course the HDD is dead, so i'm looking to upgrade it to flash memory. the problem is that i dont seem to be able to find all the answers i need to be sure i can do what i want to do to it.
question 1: the original HDD in the ipod is 160 gigs. I'd like to replace that HDD with a flash memory drive that will be a larger capacity of storage, but how much storage can i used with this Ipod? Is it possible to put a 1 TB flash drive in it and have it actually store and use that much data?
question 2: is there a guide for this particular model to be upgraded to flash memory?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Good idea. I've seen a few tutorials here and there, however if iFixit created one it would be more trustworthy. I've used a few of them, plus I ordered, received, and installed their 5th gen battery kit. It's like having a new iPod!
EDIT: I just found their tutorial. I'm not sure about the storage capacity limits of the file system used on these iPods - that question may get better responses over on an Apple Support or iPod specific forum.
完成的
添加一条评论
1个答案
最有帮助的答案
There is a guy that sells boards for use with microSD cards, SDXC, CF, and mSATA storage. I suggest checking out http://iflash.xyz . To better explain, yes, you can put a 1TB mSATA SSD with the appropriate board, however, most recommend also replacing the original battery with a larger capacity battery if you're planning on using an mSATA.
If you don't want to replace the battery, you can go with SDXC cards. They tend to come in capacities of 128GB, 256GB, and some in 512GB. They will use much less battery than the mSATA SSDs and I would like to some day upgrade my iPod with a couple of 128GB SDXCs.
I recommend staying away from CompactFlash since they're pretty dated and come in limited capacities (I've seen most around 64GB).
As I said before, you can go with a 1TB mSATA but you'll also need a new battery so that's up to you, you can go with just 1 mSATA or you can buy a quad microSD or Dual SDXC adapter and go with that.
Either way, the above website still has plenty of resources and guides with comparisons of runtime and performance. You can even find a couple of videos.
I hope I could help you and good luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
psychonaut13 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 105
总计 4,543
