跳转到主内容
由华硕制造的笔记本电脑。
2530 个问题 查看全部
Asus laptop not turning on and no lights.
My Asus K55V laptop not turning on or no lights blinking when connected to power adaptor or with battery.
I shutdown and put it in charge overnight and morning it is not getting On.
Plz help....Thankz in advance ☺
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
9条评论
Did you do anything to the previous night that might affect it? Anything at all? Did you rock it, sock it, or pick it up and drop it? Did you install any software?
完成的
No i didnt. Juz put it on charge.
完成的
I couldn't get mine to turn on and the battery isn't removable. Tried many things, then decided to get creative. I made this up, and it worked: attach HDMI cable to the laptop and to tv, turn on tv. Then press and hold the laptop on button. It took a few tries, but it worked.
完成的
Why is it not working I don't understand I've got a new charger an all of a sudden it just won't come on
完成的
Attention Purchasers of ASUS Rog Strix GL502VS and GL502VSK If you purchased the laptop in the United States Between May 4, 2014 and November 19, 2019. Then you are entitled to Cash Payment of up to $110, or Credit Certificate of up to $210 from a Class Action Settlement. The Laptop can cause physical discomfort to people and/or diminishing the Laptops’ performance by power draining of the battery even when plugged in. You MUST file a Claim online at website below by April 03, 2020. https://www.asuslaptopsettlement.com/
完成的
显示更多的4条评论
添加一条评论
3个答案
最有帮助的答案
Oh, I have this other solution to make your laptop ASUS on. (Based on my experience lol)
I used my laptop and do whatever and suddenly my laptop was shut down. I charged it and wait until the battery is full (The lights indicated)
After I plugged out the charger. I open my laptop and it didn't turn on.
So, starting that time, I didn't use my laptop for how many days, I guess 3 days or 4 days.
And I decided to open my laptop and boom! My laptop turn on.
That was my experience, and I'm so gladly that my laptop is baaaaack. ☺
这个答案有帮助吗?
得分 1
3条评论:
what if it's not charging too?
完成的
Hello everybody here, The Asus laptop that I have been using is not turning on, the battery is dead, a few days ago, the laptop died, I got if fixed, turned it on, the same, laptop won't turn on. Does anybody have suggestions?
完成的
Think I’m going to stop buying ASUS this is the worst experience I’ve ever had with a ASUS machine. I bought my daughter a visiobook for college what an absolute nightmare. 3 months after Christmas and it stopped charging sent it off to be fixed and it returned working not even a year in and back to the same old problem plug it in won’t charge. Go to the help pages and they tell you to do a hard reset and try again then it goes from one extreme to another check your hardware and drivers ! How can I check my hardware or drivers if I don’t have power! Beggars belief.
完成的
添加一条评论
Quick fix hold your Ctrl and alt plus your escape and power button til the power button stops blinking or shuts off completely then wait a minute or so and then power on as usual. Should turn back on.
这个答案有帮助吗?
得分 1
3条评论:
Thanks worked first time :)
完成的
Cheers, this worked for me too !!
完成的
it worked! but why though? why did that happen?
完成的
添加一条评论
Please check if the AC adapter connector is loose (marked in the image below: A-power cord plug / B-outlet side plug / C-NB side AC jack), or you can try connecting to different outlets. Please check if the adapter or cable is damaged. If there is any damage, please contact ASUS service center for further information
Regards,
Will
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sreejith SivaGeeth 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 23
过去 30 天: 103
总计 76,530
