跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
iPhone 5c won't turn on after cleaning camera
I have an iphone 5c, looking at it I noticed my rear camera was dusty so I decided to clean it up. Everything went fine as I took the phone apart, but when I finished and closed my phone up, it would'nt turn on. I'm not sure what to do, everything seems to be connected inside. However, while I was fixing my phone it turned on and I had to turn it off while it was still opened up. Could that have been the problem why it is not working? If not, what else could it be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
To answer your last question, yes that definitely could be the issue here. Keeping your battery plugged in while working on the phone can cause the logic board to get shocked and shorted out. That is probably what happened. So it doesnt show signs that it is coming on at all? like it does not vibrate or anything? it just completely wont come on?... If it doesnt, i would suggest taking it to apple, or sending it in to see what they say. I wouldnt tell them that it has been open or anything because they can turn you down for that. If it shows signs of coming on, like vibrating, making any sounds then its possible to be fixed, but that would require some expensive micro soldering work. And still in this case its cheaper and better to talk to apple. I hope This was of some help!
这个答案有帮助吗?
得分 0
1条评论:
@sirfixalot24434 No it does not turn on or make any noises what so ever. I will try talking to apple about it, thank you, you did help me.
完成的
添加一条评论
添加你的答案
Isabel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 77
