跳转到主内容
27“显示屏,分辨率为2560 x 1440像素 Thunderbolt&MagSafe电缆附件
160 个问题 查看全部
Monitor not working at all?
I bought a used Thunderbolt Display. It was sent to me and I wasn't able to check it upon purchase. When it finally came, I saw the housing was in very good condition, no scratches, no bumps. Cables are fine and clean. When monitor is plugged in to a power supply my MacBook Pro can be powered too (the small led correctly indicates charging).
However:
- USB ports dont charge any connected device (like iPhone)
- when connected to laptop, the monitor is neither listed in the monitor list, nor in the thunderbolt section (computer states: no thunderbolt devices connected)
- the same when monitor is connected via a separate thunderbolt cable (not the one going out of the back housing)
What can be wrong? Is there a chance to fix it by myself or service is required?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The most common problem with the Thunderbolt Display is the cable connecting to the laptop. replacing that one might fix it.
If you have a male to male thunderbolt cable, you can put it in the thunderbolt port on the back of the display, and the other one in your mac, if the screen works fine that way. It is the cable that is having issues.
Replacing the cable is not that hard, but you need the right tools and need to be careful.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
MonsterSale 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 429
