跳转到主内容
加入维修社区 - 创建账户
The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
Hang at samsung logo
Hello , My samsung galaxy note II hang at samsung logo and i cant get recovery mode and when i trying to flash the phone from odin called me ( Fail ) i dont know what i do help me please
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Which stage on Odin does it fail at? I have had some cases where the cable was bad. Particularly some original Samsung ones because they got worn out from plugging in a lot.
完成的
I use original cable but i think its bad from the head
完成的
添加一条评论
2个答案
已选择的解决方案
Not being able to boot recovery mode means the recovery partition in the internal memory of the phone has become corrupt / unreadable.
You may be looking at a board issue which is not fixable unless you replace the logic board and that would basically cost pretty much near the cost price of the phone 2nd hand.
You could try another cable and flashing it via ODIN again but I doubt it will work because the memory chip sounds corrupt / gone faulty.
I have had my share of a bad cable causing a flash to fail. If it is the original one you have been using for a long time I highly recommend another cable first before giving up on the phone.
这个答案有帮助吗?
得分 2
1条评论:
Samsung Galaxy Note 2 boot logo
完成的
添加一条评论
最有帮助的答案
Hello, so sorry to hear about your problem. I am not really 100% sure what the problem could be but my first guess in this type of situation would be to think that there is some type of shortage in the battery. I would suggest trying a new battery and see if it goes all the way through. Hope this was of some help. Have a good day!
这个答案有帮助吗?
得分 2
1条评论:
If the problem from battary why i cant get recovery mode ?
完成的
添加一条评论
添加你的答案
abdulla muthana 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 55
总计 5,494
