跳转到主内容
The second generation of the Samsung Gear, a round smartwatch running Samsung's Tizen smartwatch OS. The Gear S2 was released in October 2015.
72 个问题 查看全部
Bezel ring repair or replacement
My bezel ring fell off my watch. Can you fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
2条评论:
My bezel ring is very difficult to turn either direction it's very sticky , how can I take it off and clean it and put it back on
完成的
添加一条评论
6个答案
I just found this a few days ago. I have ordered the parts. :)
https://www.youtube.com/watch?v=puASQxWC...
Much luck!
这个答案有帮助吗?
得分 0
2条评论:
where did you order from?
完成的
You can find them on eBay and on Amazon, the Amazon ones are for the rolex submarines, but I would think that they can work, the link is https://m.aliexpress.com/amp/item/327710... . Keep in mind that you will have to find out the size of the watch face or bezel so that the insert will fit perfectly and so that it may not even need the use of glue. So I would suggest going to a jewelry store and seeing if they can inform you on the correct size insert to buy. And you can get it from multiple different sites, not Just the one I provided.
完成的
添加一条评论
You can Glue it on with gorilla glue or sticky silicon glue. The inner part of the bezel is called a bezel insert, I have looked all over the net for ways to repair it and have only found one video as listed by the poster above. But if you entirely lost your bezel insert on the street or anywhere and do not have one in possession, you can just get a bezel insert from a old watch or order one . After getting a new insert, you can just glue it on. Just be sure to find the right size, for example: if the bezel size is 44mm, buy a 44mm bezel insert. This will work.
这个答案有帮助吗?
得分 0
添加一条评论
looking for the parts. I lost the ring and all
这个答案有帮助吗?
得分 0
添加一条评论
https://rounded.com/gear-s3-frontier/
这个答案有帮助吗?
得分 0
添加一条评论
Lost my bezel anyone know where to replace it
这个答案有帮助吗?
得分 0
添加一条评论
My bezel fell off my Gs2 watch how easy to get another and repair?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Frank Sutterby 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 9
总计 23,920
