跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Why is my Vibration not working?
Didn't do anything to my iPhone besides using it like normal. One day, my Vibration fails to work. I tried spamming the ringer button and looked into settings. Enabling/Disabling the ringer in settings makes a weird click sound initially.
I even replaced the Vibrator in the iPhone too see if that was the problem. It wasn't. Not sure what else to do. Any help would be appreciated.
Thank You
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Try to test connection dock of the vabrator maybe it has a small shorted there or dirt if it not work try to the replace new one part
这个答案有帮助吗?
得分 1
1条评论:
OP: Also good thing to check continuity of the vibrator connector points to the ribbon connector pins via a digital multimeter if you have one on the logic board. Should beep to indicate that there is no broken connection between them.
完成的
添加一条评论
添加你的答案
TwoJayCee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 247
