跳转到主内容
加入维修社区 - 创建账户
Gaming laptop released in 2014 with an Nvidia 860M graphics card and a 15.6" display. Updated in 2015 with 960M graphics.
CPU overheating, high temperature even while surfing the net
Hi everyone! I have the following problem:
CPU temperature constantly outside the norm. Even after replacing the thermal paste and full cleaning of dust nothing has changed.
When I'm surfing on the net the CPU temperature is 55-65 deg on balanced power mode.
When I start system stress test - after 3 min i get CPU overheating.
All drivers is up to date according to lenovo site.
OS: Windows 10 x64
I suspect case in the BIOS version, but it also updated to the latest version.
Have any ideas?
Stats of my laptop temperature while I'm working (just coding web application)
And stats of friend of mine during the same working process
Update (12/16/2016)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
Open task manager. Take a few screenshots of the CPU performance graphs and such. However, don't allow that other program (the one in the screenshots) to run in the background.
完成的
Please see screenshots below.
完成的
Hmmm. Is there any physical overheating? Do you feel it getting hot or can detect that the fan is running?
完成的
Yea, the front of laptop is warmer that it should be.
When I just working I hear how the fans are accelerated greatly.
I will add screens with my temperature stats and friend of mine with the save laptop model.
完成的
Please see updated question description
完成的
添加一条评论
3个答案
已选择的解决方案
So diagnosis service center showed that the cooling system is working properly but the problem in stability of the video card and it requires replacement of the entire motherboard. Perfectly! Awesome laptop!
I do not recommend anyone buy Lenovo products, especially gaming laptops.
这个答案有帮助吗?
得分 1
添加一条评论
Same happened on my y500 :'-( I'm getting a motherboard replacement. but I agree I think Lenovo isn't worth it. from the moment I got my PC the blu ray player wouldn't work. I was out of the country so never had the opportunity to use its warranty.
这个答案有帮助吗?
得分 1
添加一条评论
Yep, the graphic card on the PC i am writing from now which is the one the post is about is a ##&&%, had to lower high performance cpu usage because it would overheat together with the GPU in the machine. When I opened the machine the outflow socket of the hot air was “burned” like molten plastic, but it still works for me.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vasyl Semilyak 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 29
总计 7,216
