跳转到主内容
苹果个人电脑产品线 iMac 系列的首款机型。 iMac G3 发布于1998年至2003年之间。
How to wipe iMac G3 HDD when it is not detected?
Hello!
I've got an old iMac G3 700 SE. It's a slot-loading "summer 2001" model (Graphite) with a 700MHz PowerPc processor. I've got two desires for this Mac:
1) Totally wipe the memory. It was a family computer and my mom wants it securely wiped before she'll let it go. This is sort of the primary goal; if the computer isn't worth salvaging after that, I can live with that outcome.
2) Get it running OS9 if I can. If I can make this computer work, I'd enjoy using it as a retro gaming rig. (It used to have OS9 and OSX partitions on it.)
And I think its hard drive may be a goner. I've got a few questions. Here's a breakdown of what's happened so far:
  • 7 or 8 years ago, the computer suddenly had the "flashing question mark / system folder" issue where it can't find an OS to load from. It was retired.
  • I plugged it back in today to try to see what I could do.
  • Reset PRAM, SMC. Opened start-up manager, where nothing was found.
  • Loaded to Open Firmware screen and reset the open firmware settings.
  • Unexpectedly found the original discs that came with the machine. So I've got OS 9 install CD, OS X install CD, 3 Software Restore CDs, a CD of Applications, and an "Apple Hardware Test" CD.
  • I booted from the OS9 disc successfully, but could not install the OS as the computer still can't find the hard drive.
  • I'm currently trying to run the Hardware Test CD, but having trouble with the cursor not moving. I had this trouble for a while when I was opening the startup manager. Not sure what else to try here. I've had to plug a newer optical mouse directly in the computer's USB port rather than the keyboard in order for it to work at all. The laser is on now, but no movement. Darn.
So, my question is - what now? Is this definitely indicative of a completely bricked hard drive, or are there other things I should try?
If the hard drive cannot be detected, is there a way I can be sure it's wiped of all its memory and safely disposed of? (The idea of opening up the computer to physically remove the HDD makes me a little nervous, I admit; I don't want to get shocked or anything. But if that's how to do it, I can.)
And is it worth trying to get the computer to run on another drive somehow? What would be the easiest way to do that? Would I have to install it directly in place of the apparently-broken one, or can I use an external one or something?
Thanks in advance for any help! This is turning out to be pretty challenging, but I'm determined to at least cleanly delete any data from the computer, and I'm certainly willing to continue trying to get it running functionally. I'm learning through Google searches as I go, so the more detailed responses, the better. I am not terribly knowledgeable.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Your systems specs: iMac G3/700 SE (Summer 2001)
完成的
添加一条评论
1个答案
最有帮助的答案
It definently need a new hdd, to wipe the old one just hammer the hdd :) The install disk is available online, it is an ISO file so you can use Windows or a Mac to burn it to a cd. It is called macos9lives, I don't think I can provide a link though...
这个答案有帮助吗?
得分 2
8条评论:
I've got the OS9 disc that came with the computer, and it's functional. Would that not work well for a new HDD?
If I need to, I can find a 9.2.2 ISO and burn it. No worries there.
So the HDD is just borked for sure, huh? Nothing more I can do now unless I install a new one? I'm guessing since I will already have to go in and physically remove the junked one, it would probably be easiest to just install another one while I'm in there.
I guess another good question is whether it's cost-effective to get a new HDD in a size the iMac will be happy with.
So, just so I've got everything straight, I should:
* Research how to safely open the computer itself and remove the HDD
* Do that, smash the offending thing, and install a new one in its place
* Boot using OS9 CD (whether a burned one or the original if it'll work)
* Install OS9 to new HDD
Thanks very much for the help! I appreciate it a ton.
完成的
Exactly, I didn't know you already had a Mac OS 9 CD, that would work perfect. Make sure when you replace the hdd don't touch the PSU or the CRT! :)
完成的
I got a bit of bad news here the HD in this series was a Ultra ATA drive. Finding a good drive will be difficult as these are no longer being made (over 10 years ago).
完成的
What about on eBay?
完成的
It took some doing I did find one that looks new Vs used: Seagate (ST3160215ACE) 160GB - 2MB 7200RPM (PATA) IDE Ultra ATA/100 3.5" Hard Drive which will work in your system. I can't speak for the seller here so make sure you use a credit card that you can get your money back from (i.e. American Express).
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Kiso 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 877
