跳转到主内容
加入维修社区 - 创建账户
Sony Xperia M4 aqua was released 2015, June. With a Size of 5.0 inches, it was operated in Android OS, v5.0.1. Sony Xperia m4 Aqua has internal of both 8 GB, 2 GB RAM/ 16 GB (E2306) And it has 13 MP Primary Camera and a 5MP Secondary Camera. This phone has a non-removable Li-Ion 2400 mAh battery.
I can't make calls, why?
Hi everyone,
I need help with my phone (Xperia Aqua M4) because I can't hear anyone I call since almost 2 months now (I have this phone since August 2015). I can listening music if I use my earphones and the speakers works for make calls. But the primary function of my phone doesn't work. I tried to clean the orifices with alcohol 70% and a Q-tip. I found a lot of dirts (I work as a gardener, so). But that was not effective.
Any ideals?
Thank you for your help,
Alexe
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Alex,
If the only speaker not working is your earpiece speaker, it may need replacing.
There are quite a few videoes about on YouTube and a guides here on ifixit to help.
But opening the Xperia will more than likely void any water resistance that phone has, as it is held together by double sided adheshive.
这个答案有帮助吗?
得分 3
1条评论:
Hi Ged,
Thank you for your answer!!
I will give a try! That will be nice if that working well. Maybe I will be able to find double sided adhesive on asian market! A lot of store told me they can't repair it because the screen risk of cracking.
完成的
添加一条评论
添加你的答案
Alyrxc 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 1,400
