跳转到主内容
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 个问题 查看全部
What Could Be Causing a Dead Internal Display?
I recently got a family member's MacBook Pro to recover data from, since it was damaged in a home flood.
It turns out the the computer still works, for the most part. I used Target Disk Mode to initially clone the hard drive, but I plugged in a display into the MiniDisplay Port and the computer actually runs perfectly fine in clamshell mode.
Is there a way that I could diagnose the exact problem, or even repair the computer? Thanks!
Also of note, the green light by the webcam does still turn on, but i've yet to actually test the video feed.
Update: It turns out the backlight is damaged.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
See if you can use a flashlight to shine though the Apple logo (poor mans backlight) are you able to see a faint image of the desktop icon's? If you are you've localized the problem down to the backlight circuit. If not you'll need to pop the bottom cover off to inspect the logic board connection where the display is connected. Take a couple of clear images so we can see and paste them here.
这个答案有帮助吗?
得分 1
5条评论:
Thanks! I tried shining a light through, and I could see the desktop. Would resetting the SMC help?
完成的
It's worth a try but I doubt it'll help.
完成的
Okay. You're right. It didn't do anything. How would I go about further diagnosing the backlight?
完成的
You'll need to pop the bottom cover off to inspect things. You could have a burnt fuse link or the backlight driver is burnt. This maybe getting on the deep side if you don't have the needed micro soldering tools or access to the parts
完成的
Hmm. I am no expert, nor do I have the tools or parts on hand to do a lot of extensive work. I can certainly inspect the logic board for damage, but there's not much more I could really do..
完成的
添加一条评论
添加你的答案
Jake 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 69
