跳转到主内容
MacBook Pro 13寸显示器版本
9742 个问题 查看全部
Battery indicator has an X, and charger light stays green,
My battery indicator at the top of the screen has an X inside it, and the side indicator when I press the button doesn't light up to show how much battery is left. When I plug my charger in the light goes straight to green, I can't tell if its charging or not because of the X in the indicator. I turned my laptop off and on again and its still the same. Also it sounds like the fan over-heater things (i'm so not tech savvy so bare with me lol) are going off loudly, (sounds like a hair dryer just not as loud) yet my laptop isn't hot at all. I've closed all applications and tabs so really, my laptop shouldn't be over-worked as it should't be doing anything.
Hope someone can help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I should also mention its still on atm, it hasn't ran out of battery or not turning on.
完成的
添加一条评论
1个答案
已选择的解决方案
Try an SMC reset, more information on how to do it here:
https://support.apple.com/en-au/HT201295
The key combination is to hold Ctrl + Shift + Option when turning on the MacBook. You only need to press and hold the power button for 5 seconds when doing that.
If that does not fix the problem then you may be looking at possible liquid damage on the board causing this.
这个答案有帮助吗?
得分 2
1条评论:
thank you so much, that seems to have done the trick!
完成的
添加一条评论
添加你的答案
princesstye 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 128
