跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Screen displaying weird lines (See Pictures)
Hi there! My screen is unresponsive and it is also showing weird lines on it. I tried disconnecting the flex cables and reconnecting it with no avail. The screen is not cracked or damaged externally.
Thanks everyone!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Try a new screen if you have tried reconnecting. Usually blocks of lines can appear if the touch is not plugged in properly or recognised. Check the connector on the board also.
这个答案有帮助吗?
得分 2
添加一条评论
Looks like your LCD went . I would try a new screen assembly. If re seating your cables didn't work , then looks like the LCD went out
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alvin Lee 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 1,125
