跳转到主内容
加入维修社区 - 创建账户
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
Upgrading my MacBook Pro's RAM
Hello,
For a while I've been trying to change my MacBook Pro 13' Mid 12' 4 GB RAM.
In checking Apple's own tutorial HERE, I found out that I can only increase my RAM to maximum 8 GB and for better performance I should implement two 4 GB RAM modules rather then one 8 GB module.
So my questions are:
  1. Can I in anyway possibly change my RAM to 16 GB or is it merely impossible?
  2. Is the performance with the two 4 GB RAM much better then with one 8GB RAM? Is it worth paying nearly the double amount for such performance?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Standard RAM: 4 GB Maximum RAM: 16 GB*
Details: 4 GB of RAM is installed as two 2 GB modules, no slots free.
RAM Type: PC3-12800 DDR3L Min. RAM Speed: 1600 MHz
*Apple officially supports a maximum of 8 GB of RAM, but third-parties have determined that this model actually is capable of using up to 16 GB of RAM with two 8 GB memory modules.
这个答案有帮助吗?
得分 4
3条评论:
Thanks for the answer. But how trustworthy are those third parties? Am worried if it well not work or even worse cause any damage to my macbook.
Thanks Any way!
完成的
Very trust worthy!
完成的
Double that here! We've boosted quite a few MacBook Pro's to 16 GB without a hitch! One thing to make sure you use a matched pair of modules (bought at the same time from the same source).
完成的
添加一条评论
添加你的答案
nawaf mohammed 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 164
