跳转到主内容
加入维修社区 - 创建账户
4.7" Motorola smartphone released in 2012. Identified by model number XT926.
My mobile won't turn on. The red M just looks like it's booting up.
The red M looks like it used to look when it was working. It's as if it's stuck in a loop. It turns on or off whenever the battery dies. The memory is full ( internal ) so I purchased an SD card but didn't know how to transfer files and pics so never used it.
Should I just chuck it out or is it repairable?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi George.
It's a sealed unit. I can't get the battery out. I suppose I'll just smash it then chuck it out.
Thanks for your reply.
Gillian
完成的
Mine would go past the M to a loading screen then hang forever. I had to do a factory reset. Then it worked much better. If you can get it to load you should be able to transfer apps and photos (etc.) to an SD card. It will probably be painfully slow until that is done.
完成的
添加一条评论
1个答案
Try taking out the battery and then plug it in to USB port.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
gilliansmith 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 118
