跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 个问题 查看全部
Why is my 3DS Not Charging?
I recently took out my 3DS and upon trying to charge it, the charging light would not appear. I assumed that the system's charger port was broken, which I researched could be a couple different issues: the two pins on the inside of the port could have been bent, and would need to be bent back into shape to get it working. That didn't do it, so I opened the system up to see if there were any broken connections to the port. They were all in tact, but I applied extra solder to each of them just in case. It didn't fix it. Here are some pictures:
Are there any other reasons the system wont charge/the charging light wont appear? Any fixes?
Thanks in Advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论:
I have the same problem to,but i never opened my 3DS to chek whats wrong.
完成的
添加一条评论
1个答案
I would suggest taking a look at the devices battery. You can buy them on eBay for about £5 new. Possible but unlikely one of the fuses in your device could be fried.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael Hays 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 632
