跳转到主内容
Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
My PS3 controller will not turn on at all?
My PS3 controller wont turn on - no red flashing lights - no response to being charged or reset. Also, when the controller used to work, I accidentally hit it - not hard - against my fan and then it sounded like something was broken inside of it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
find a set of star screwdrivers and open up the controller then detach the battery connector from the board of the controller then try connecting it with the usb to your console and do a reset on the pad it should work if it does probably your controller is dead
这个答案有帮助吗?
得分 1
8条评论:
Ok will try thank you!
完成的
So am i pretty much just removing the battery
完成的
It did not work
完成的
then it should be a board issue
完成的
suggest u get another controller then
完成的
显示更多的3条评论
添加一条评论
Solved ! Get the same usb type cable with data support.. like printer cable so that your ps3 controller can be detected by laptop/PC . You will see the controller lights blinking the moment you insert in the PC (install the drivers first or win 8 which has pre-installed drivers for ps3 controller). Insert and remove couple of times the USB cable until your ps3 controller is able to start up (don't start playing immidealy let it charge first) ..then charge normally . I once tried this with dead iPod it worked and it worked with my PS3 controller too.
这个答案有帮助吗?
得分 0
添加一条评论
My ps 3 controller is not working not blinking light
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
SilverLordGamer512 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 28
总计 10,031
