跳转到主内容
发售于2014年春季 的一加 一拥有着5.5英寸的显示屏 运行着基于Android的CyanogenMod 12S操作系统。
110 个问题 查看全部
OnePlus One wifi chipset replacement
I was wondering if the oneplus one Qualcom chipset could be removed from the motherboard and replaced with another manufacturer chipset. I know that is it likely laminated to the board. Is it still possible to remove the chip? Even with moderate difficultly. Also I was wondering if anyone had the pin outs for the chip? I love the phone but could really use another chipset as I don't want to run an external wifi via the USB.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
As you can see in this link the Wifi chip is rather small. I would call difficult to extremely difficult to solder of the chip and change it.
一加 一拆解
It should be easier to perhaps fins a used motherboard and change that.
But you could also look at the Oneplus forum
https://forums.oneplus.net/forums/tech-s...
这个答案有帮助吗?
得分 0
2条评论:
I'm looking to replace the wifi chip with a different manufacturer. Specifically RealTek. I'm looking for a wifi chip that can be placed into monitor mode in order to assist in wifi troubleshooting without having to lug around my laptop or using an external usb wifi. I will be running a linux distro on the OnePlus with the RealTek firmware already installed.
完成的
To install another wifi chipset sounds very difficult since the pin layout would have to be the same.
完成的
添加一条评论
添加你的答案
Wes Mongold 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 1,351
