跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1197 个问题 查看全部
URGENT MacBook won't turn on without battery- Solved
Mid 2010 unibody macbook a1342
The battery was bulging so I took it out. Then I Try to power with power cable only but it's not turning on. The cable is making contact it's green. I need to edit a project and the bulging battery makes the trackpad not work it's that bad. Help me please.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
I figured it out. I disconnected the keyboard somehow and didn't realize. I plugged it back in and it's fine. Thanks
这个答案有帮助吗?
得分 1
1条评论:
Mac book not start without battery .
完成的
添加一条评论
If you have removed the battery, you can still run the MacBook by connecting it to an AC outlet with the included AC power adapter.
Unplug the power adapter, Ethernet cable and any other cables from the MacBook. Wait 10 minutes if you have been using the MacBook to allow it to cool off.
Plug one end of the power adapter into the power adapter port on the MacBook and plug the other end of the power adapter into an AC outlet. Turn the MacBook back over and put it on a table.
Press the power button and hold it for up to one second, until you hear the startup tone, to turn the MacBook back on.
这个答案有帮助吗?
得分 0
2条评论:
Had the same issue, turned out to be the keyboard connector as well, thanks for the info. I assume there was dirt inside the connector or it wasn’t plugged in correctly, but to be fair, that one is a bit difficult to get seated right anyways
完成的
done with my battery-less MacBook Pro 2015 (mid 2015) didn't work. boots almost to the end and the reboots :-/
The batteries where bulged a lot, discovered due in an routine inspection do clean the inside. I was afraid and removed the batteries (quit a job but I used a dental floss ^_^ to cut thru the glued, it works really nice) to keep working no my Mac. No go... a 2900€ laptop that cuts me deep like that - cant run without batteries. really considering my next Mac be a hackintosh laptop or so.
完成的
添加一条评论
添加你的答案
Darren 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 41
总计 23,419
