跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Why won't my phone go into recovery mode?
I'm trying to put my phone into recovery mode but when I hold the home button and plug it into the computer it just starts up like it normally would instead of going into recovery mode. Can anyone tell me what I'm doing wrong?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
6条评论
Use a standard charging cable plugged into the wall then press and hold the power and home button at the same time. Keep holding until recovery mode is showing on the screen. Then plug into iTunes to restore or update. I have found that iTunes is the problem with my phones entering recovery mode.
完成的
I keep trying that, but all I ever see is iTunes 'restore', not computer 'recovery' screen.
完成的
My home button is pushed in to far.. what do I do now?
完成的
Iphone 6s is not showing recovery mode even holdind home and power button
完成的
My iPhone was giving me a similar problem when I was attempting to put it on recovery mode. I however conducted research and found a solution on this link: https://bit.ly/3dc6Zm1
I hope this will be helpful
完成的
显示更多的1条评论
添加一条评论
4个答案
已选择的解决方案
Keep the phone plugged in. Hold home and Power for 8-10 seconds or until the phone turns off.
You may need to hold the power button again for a few seconds to make sure the phone switches on again while plugged in.
Keep holding home button when doing so until it shows the iTunes recovery symbol.
这个答案有帮助吗?
得分 10
8条评论:
have tried this many times but still doenst work
could there possibly be a hardware issue preventing me from putting into recovery mode?
完成的
Which iPhone? iPhone 7 and 7 plus specifically need you to hold the volume down button and power to boot into recovery mode instead of holding the home button (home button does not work / function until the phone is booted)
完成的
I'm not allowed to downvote this. But this was useless.
完成的
Lol yeah ok. If your phone absolutely refuses to go recovery mode then obviously the phone has a major hardware issue most likely board level.
https://support.apple.com/en-au/ht204306
If the phone switches on fine you can reboot to recovery mode via 3Utools on the multiple flash tab.
完成的
Josh O'Brien useless to whom? The question by the OP was for an explanation on how to boot the phone into recovery mode. The steps that the OP took were corrected by @benjamen50. No further response from the OP followed that answer. So, I am sorry that you feel that this was useless and it may not have helped you but there would be no reason to downvote it. Downvotes on here are usually reserved for blatantly wrong or malicious answers but not for answers that one does not like.
完成的
显示更多的3条评论
添加一条评论
最有帮助的答案
DO NOT plug into iTunes use your standard charger and cable. Plug your phone into your charging cable then press and hold the power and home button (depending on your model of iPhone) until you see it go into recovery mode. When you see the recovery mode indication on your screen unplug from the wall charger and plug into you iTunes device then began your restore or update.
这个答案有帮助吗?
得分 22
10条评论:
Thank you sir. I did it.
完成的
I spent an hour trying to find the correct method to make this happen with a A1532 iPhone 5. Thank you. Seems a little silly that this is what the answer is but it worked! Thanks, Jonathan!
完成的
Bingo! -- Would be a helpful thing for Apple to tell you on their support page -- eh?
完成的
Sooooooo HELPFULLLLLLLLL! THANKS :) :) :) :)
完成的
WoW...THANK YOU!!!
完成的
显示更多的5条评论
添加一条评论
It looks like you have a faulty home button, does your home button work 100%?
这个答案有帮助吗?
得分 1
2条评论:
I upgrade my iPhone 6s and it goes to dfu mode and I cannot solve it because it stays in this situation
Plz help me and answer me if I downgrade to lower ios this problem will fix ????
完成的
Same to me :(
完成的
添加一条评论
my phone goes into recovery mode but when the iTunes extract the software then it suddenly turns off. plz help
这个答案有帮助吗?
得分 0
2条评论:
and it goes back into recovery mode again.
完成的
Maybe, just maybe, try a different iPhone cable. I feel like that happened to me once and the cable was faulty.
完成的
添加一条评论
添加你的答案
Logan Winward 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 57
过去 30 天: 240
总计 92,926
