跳转到主内容
加入维修社区 - 创建账户
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
Homebutton is stuck but sensor works
Hello,
My homebutton of my ipad air is stuck, i can't press it anymore.
But when i press really hard than it works , what is the problem then is it the homebutton self or the cable with the sensor?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
did you tried doing a hard restart on ipad . see if that help . just press the power key and hold for like 30 sec . thanks
完成的
That is Unfortunately not a solution for me because i can't click anymore on the homebutton it is not the software , but the hardware. thanks anyway for the suggestion
完成的
添加一条评论
2个答案
已选择的解决方案
It will be the home button ribbon most likely. May need the plastic and rubber seal replaced around the home button, it is it getting stuck under the screen. You need to open this and check it out.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
I always try everything I can on iPads before I open them, since opening them almost always means a new screen.
Try cleaning the power button out with 99% IPA. Give it a good soaking and scrubbing. You won't hurt anything that isn't already hurt. If that doesn't fix it, its most likely just the glue on the bracket working loose after years of use. If you are pressing down on the button and it doesn't "feel right", its a safe bet that its just the bracket. It also could be that the bracket isn't lined up quite right because of a drop. It happens.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Sander Messiaen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 20
总计 1,732
