issues after screen and battery replacement
Hello,
I recently replaced the screen, battery and lightning port on an iphone 6, it was working and charging fine for a day or 2 then it stopped powering on. The computer recognizes when I plug it in...
Could be a bad battery. I would put the old one back in just to test it. If that's not the issue, it could be a charging port issue. If neither of those are the problem, it could be a more serious issue.
这个答案有帮助吗?
I tried a diff battery and screen. I'm afraid you might be right.
I've done some more reading and people seem to think it's a logic board issue
If iTunes recongnizes it could've blown a backlight filter or shorted the backlight line. This happens a lot with aftermarket screens on the iPhone 6 and 6s. Does it look dim (can you see a dim apple logo when it boots up) or no backlight at all?
这个答案有帮助吗?
Just curious, does using a phone flashlight help with seeing the dim apple logo on a backlight issue iPhone?
All replacement parts came from ifixit.
Also to add in there is a chance of it blowing when you plug in the screen connectors with the battery still plugged in.
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 107
