跳转到主内容
Keyboard mechanism retaining clips broken
I've been attempting to repair a broken key mechanism for a MacBook Pro 13" Retina (Late 2013, model A1502) which I've been given. When trying to reattach the mechanism to the keyboard I've noticed that two of the four retaining metal clips where the mechanism locates on the keyboard circuit board are broken.
I've uploaded a photo (see here), if you look at the bottom of the area where the key is missing you'll see that there are no clips. I've removed the down arrow and can see that there should be two sets of two clips.
I know the keyboard for the Retina models is part of the upper assembly so a swap out is no go. At the moment only the upper retaining clips are present meaning the key falls off easily. Does anybody have any ideas on how I can fix this so that the key stays on? The only ideas I have are to attempt to solder new clips on or to try and attach something to the bottom edge of the up arrow key to feed under the down arrow key.
I think this is unrepairable without spending £££ and lots of time but if anybody has any magic ideas they would be appreciated. Thanks!
Update
Thanks for the replies folks. I've marked up the original photo to show what is missing, it's the metal clips which stick upright from the keyboard base (they've broken off). I replaced the plastic butterfly clip on the key, it's only when I attempted to attach the key that I realised something was missing.
It looks like this is beyond repair balancing cost / effort. The solder suggestion was to attach fabricated clips but the chances of them lasting and the heat of the soldering iron not damaging something are slim. The best effort fix is to stick electrical tape over the key to stop it falling off!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Not sure from picture, but definitely using a new plastic mechanism of the same type as before?
Best solution (most long lasting too) is to just replace the keyboard (not whole palmrest). You have to remove the old rivets using wire cutters and screw in the new keyboard (which can be a bit daunting for first time), but it will ensure the issue won't happen again. Keyboards cost around £12-£20.
Could try soldering something, but wouldn't see it long lasting since it will be part of a moving mechanism.
这个答案有帮助吗?
得分 2
3条评论:
Soldering would just make things worse as it will melt the plastic not shape it.
完成的
Yes, I'd definitely recommend just replacing the keyboard. I think OP was just talking about soldering something to the metal of the keyboard (not plastic), but I reckon it would not last.
完成的
if I understand right it is not part of a moving mechanism but the support the hinge snaps into.
完成的
添加一条评论
Sadly the hinge pin is damaged and not repairable.
This issue here is what is your skills and how much things cost.
Yes, you can replace the keyboard unit alone Vs the whole upper case. But its quite a bit of work and you do need to be careful as you could end up with a mess.
You could also go to an Apple store and pay the bench fee plus the parts cost and have the complete upper case replaced while it's the most expensive option it also removes the risk of your lack of skills.
The last option here is to replace the upper case assembly your self. Here you could save some money getting a refurbished part (used) and do the work your self while its still quite a bit of work its a lot less than replacing the keyboard and is the least risky.
这个答案有帮助吗?
得分 1
添加一条评论
Is the hinge clip, i.e., the metal part that the white plastic hinge snaps into, really part of the upper case? Then why do people say replace the keyboard? Has anyone got experience? I have unfortunately bent one of the metal clips myself and I think it broke when I tried to bend it back. But would a new keyboard fix it, or not?
Also early 2015 MBP.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nathan Pardoe 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 50
总计 9,555
