跳转到主内容
加入维修社区 - 创建账户
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
Detached home button cable
I opened my Iphone SE case too quickly/far and the cable came unsoldered. Which part do I need? I found the cable alone and the full home button. It appears the button is fine just the cable needs repaired. any links to parts/guides would be much appreciated :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Can you attach a picture to your question? That way we can see if it's fixable or not.
完成的
添加一条评论
2个答案
已选择的解决方案
it sounds like you've torn the touch ID ribbon cable, you can replace the home button for a third party one but will lose Touch ID functionality, it will only work as a home button. Only apple can recode your phone to accept a replacement touch ID button. Unfortunately touch ID will be disabled unless you want to pay apple to do the repair.
这个答案有帮助吗?
得分 2
添加一条评论
Did you rip the cable? If it just came unplugged from the Lightning connector, just plug it back in. If it is ripped, your screwed. Bring it to Apple. Sorry :(
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Derik B 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 1,011
