跳转到主内容
加入维修社区 - 创建账户
Mac mini 是最初发布于2005年1月22日的小型桌面电脑。目前,它是 Mac 桌面电脑产品线四款产品之一,主要作为一体台式机 iMac 的替代产品。
startup and boot don't works,
Hi all,
I have a Mac Mini mid 2011 i7 2x HDD 750GB and it has the following problem, it is to boot inconsentiously, it does the chime, it loads the system halfway and it turns off and on, it turns on the front led, and you hear the cooler And sometimes it goes until the maximum rotation. Keyboard is unresponsive.
Some help already tried to make the boot safe but with no luck. the
thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Pull the drive out and use an external bootable HD (USB thumb drive) Are you able to boot up then?
Update (12/08/2016)
Then the power supply is what I would focus on first. Also make sure your power cord is good and you have clean power (using a UPS (best) or surge suppressor, with either clean AC power & good ground to power the system.
这个答案有帮助吗?
得分 3
1条评论:
Yes, but not all time, I'm need put power on/off several time for Mac boot w/ chime video anda normal boot
完成的
添加一条评论
添加你的答案
guedes Jr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 138
