跳转到主内容
加入维修社区 - 创建账户
Gaming laptop released in 2014 with an Nvidia 860M graphics card and a 15.6" display. Updated in 2015 with 960M graphics.
Only Fan turns on when holding power button
Hi!
So my problem is, that my Lenovo Y50-70 wont turn on at all. Only the fan starts when holding the power or recovery button. (Fan only works for 10 secs. then the whole laptop is quiet, USB 3.0 Ports has Voltage the 10 secs. fan is running)
would be nice if i get an answear here.
Maybe the Problem is electrostatic charge. but since i cant remove the battery i ve no idea how to make a discharge.
Regards,
flo071
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Did you ever find a solution to this? I just ran into the same issue...
完成的
添加一条评论
1个答案
最有帮助的答案
One method of doing a hard reset is to remove the power cord and press the power button for 20 seconds.
Another method is, with a low battery and while charging, press and hold power button until the battery LED is off, then immediately pull the cable, release the power button, and try to power it on again.
UPDATE: Ok, I know this is an old thread but since that didn't work - have you checked the RAM?
这个答案有帮助吗?
得分 1
7条评论:
The only problem is, that the battery is not removable.
But thanks anyways for your fast answer. :)
完成的
No problem. Give it a try though, this advice is specific to your model, so it might fix the problem.
完成的
tried both of them. Sadly nothing worked. Is there any other method?
Thanks!
完成的
flo071, did you ever fix this? I just ran into the exact issue...
完成的
Matthew, have you checked your RAM?
完成的
显示更多的2条评论
添加一条评论
添加你的答案
flo071 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 3,128
