Front camera sometimes stops working after touch ic replacement.
So the touch suddenly stopped and wouldn't work. I tried another screen and still no avail. So it turned out to be the touch ic that has malfunctioned.
So I had it replaced.
The thing is that the front camera sometimes work and sometimes not.
The camera goes black until I need to restart a couple of times for it to work.
Main camera is fine and flash is fine if that makes any difference.
Could there have been something went wrong during the touch ic replacement or is it a coincidence?
Is there a way to stop this from happening?
Another thing is that the top right of screen just darkens randomly apart from the rest of the screen and when rebooted or sliding the brightness bar right it gets fixed.
Sorry for long post.
Update (12/07/2016)
@reecee @refectio can anyone give me an image for the part that needs resoldering?
Update:
Okay, so after checking on it, they told me some capacitors related to the backlight are damaged from the water. They said there is a risky way to make bridges between them for the backlight to work properly. Should I go for it??
We tried another LCD and the malfunction appeared there but on the opposite site if it matters.
2条评论
@mezo, see my edit above.
由 Minho 完成的
@refectio check update please
由 Moutaz 完成的
