跳转到主内容
Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
115 个问题 查看全部
iPad Mini 3 white lines showing across two thirds of the LCD
Hello everyone.
I have received an iPad mini 3rd gen. from a friend for me to fix. According to him there are white lines showing up on the lower 2/3 of the screen. Apparently he was using the device normally, when suddenly in the evening those lines appeared. He always handled the device carefully, but the warranty has expired a few months ago.
I now opened up the device, and reseated the LCD connector, allthough it did not help. Is this a common issue and is there a way to fix it, or is the replacement of the LCD itself the only solution here? I've included a picture of the issue.
Many thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If you've tried reseating this it will most likely be LCD damage. Plug a new one in to test it
这个答案有帮助吗?
得分 4
添加一条评论
Agree with Reece, this is a LCD fault and replacing it will solve the problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 8
总计 189
