跳转到主内容
这是由索尼电脑娱乐(现已重组为索尼互动娱乐)生产的游戏主机。PlayStation 4 Slim(CUH-2000系列)是比初版PS4更薄的替代型号,于2016年9月7日正式对外公布。
569 个问题 查看全部
no video signal when turned on
ok, i just bought a brand new ps4 slim last black Friday.and I am having this issue that when I turned it on sometimes it just doesn't give me any video signal. (i can hear it , I mean it turns on ) what could it be? then I try rebooting it but the same result unless I unplug it from the outlet and then it starts normally. help please
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Check that the HDMI port isn't loose. Does the light turn white?
完成的
添加一条评论
1个答案
Make sure the PS4 is connected to the correct HDMI port.
Try unplugging and re-plugging the HDMI cable in again to make sure you have a secure connection. If it's connected to the correct port, you could switch it to another available port and try again.
Also make sure your PS4 is up to date in updates and make sure you vents are cleared of dust and it's not in an enclosed cabinet for it to overheat.
Simple solutions but that's all I can offer besides suggesting it being serviced again.
https://www.partitionwizard.com/partitio...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alian Villazan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 177
