How to connect tablet to TV
What type of cable is needed to connect the tablet to a TV? HMDI from tablet to TV results in "signal not found". (Yes, the TV is set to HMDI for input). Thank you for your help.
Are you using the HDMI port on the device itself? It could be a Micro or Mini HDMI.
这个答案有帮助吗?
Yes HDMI cord w mini adapter connected to rca tablet ,TV screen says " no device found" , what other options are there
On your RCA tablet go to settings, click on display and then configure HDMI settings.
这个答案有帮助吗?
What do you do after or even how do you configure HDMI settings
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 13,074
6条评论
I am using the HDMI port on both the TV and tablet. Tablet takes a mini.
由 boogityboo 完成的
I now have it working. Started it with the keyboard attached, then removed the keyboard. Thanks for the help.
由 boogityboo 完成的
cant get it to work either way.what to do ?
由 Wess Reddish 完成的
I am having the same problem, HDMI cable is connected but tv says no signal. Did you find a soloution?
由 jillherbert1 完成的
I've got it working, see my answer below.
由 jillherbert1 完成的
显示更多的1条评论
